Which heads for boosted engine?
Old Jul 15, 2007 | 10:12 PM
KWIKKAR's Avatar
Default Which heads for boosted engine?
Should one go with 72cc heads or 66cc heads or Ls6 heads. i was reading in another post that if you dont run atleast 14psi + 72cc is over kill. Is that true????
I plan on only being around 600rwhp maybe 700 in the far future.
Stock Ls1 for me.
Old Jul 15, 2007 | 11:02 PM
HAMRHEAD's Avatar
I would go with the 72cc heads
Old Jul 16, 2007 | 01:44 AM
Jimmy P's Avatar
For a turbo setup, I would recommend going with the 72cc heads to lower that compression as much as possible.
Old Jul 16, 2007 | 03:55 AM
2MuchRiceMakesMeSick's Avatar
I went with AFR 225 72cc on my setup
Old Jul 16, 2007 | 04:05 AM
VINCE's Avatar
Shorty Director
So did I..
Old Jul 16, 2007 | 04:28 AM
NAVY's Avatar
I think 225 or more ( 235 , 245) CFM
Old Jul 16, 2007 | 04:45 AM
Websy21's Avatar
I too am interested in your opinions, I am going to run a stock block blower set up for now until I can afford to build a motor. I thought to just bolt on some 6.0 heads while I was in there changing the cam. Since you can get used one's cheap. This would effectively lower CR and should extend motor life, maybe even warrent 10-12psi. Ok 10psi max, do you think it would be a waste of time to bolt on unported stock 6.0 heads, a guy could always give them a quick hand polish. I know, no digrinder dammit. What do you guys think? Not trying to hijack there bud, just thought this could help a little. If it means anything from my research so far I would definely go 72cc if I were you. Thanks guys!
Ryan K's Avatar
Pathological Modifier
Originally Posted by VINCE
So did I..
Me Too!
 Michael S. Palmer
Old Jul 16, 2007 | 05:30 AM
JMBLOWNWS6's Avatar
Same here 225's 72 cc
EPP's Avatar
EPP
Smile
Stock Ls1 for me.
With your future APS twin turbo, I'd go with the 72cc heads. Bob
Old Jul 16, 2007 | 06:38 AM
NA$TY-TA's Avatar
72cc on my last 317 casting heads and my new heads
Old Jul 16, 2007 | 08:05 AM
KWIKKAR's Avatar
Ok 72cc heads it is. thanks
Old Jul 16, 2007 | 08:01 PM
slowbrakiller's Avatar
anyone need 317 heads?
Old Jul 16, 2007 | 08:13 PM
cablebandit's Avatar
i got dart 62cc 9.27:1
Old Jul 17, 2007 | 10:33 PM
Red99C5's Avatar
Stock Ls1 for me.
That's what I have been told by a guy that has installed hundreds of F/I. He also has a LS7 Z06 running 10.5:1 compression and was making nearly 900 RWHP before he tuned it down to 800 RWHP.
I put some 317 heads on my maggie motor, and lost power. I'm going back with something with some compression. If I was going to run a turbo with lots of boost, then I would go with the larger chamber on a small inch motor.
Old Jul 18, 2007 | 07:58 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Must be a lot of dish on those pistons...
Old Jul 18, 2007 | 09:33 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
stock 6.0L 72cc heads working fine for me
Old Jul 18, 2007 | 09:40 AM
Fireball's Avatar
Mine are 60cc and similar compression
Old Jul 18, 2007 | 01:21 PM
bhz28's Avatar
I am going to be using 65cc and getting 8.7:1 comp
Old Jul 18, 2007 | 02:18 PM
-32cc wisecos. I love the Wisecos..Brian Nutter is the MAN and knows pistons inside and out
