Intercooler (inlet, outlet) pics???
Old May 14, 2003 | 04:27 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Intercooler (inlet, outlet) pics???
1) Looking for intercooler pics of air to air setups. Not interested in twin intercooler pics.
2) Interested in knowing if your setup requires any mods to the radiator, like tilting it back or anything like that.
3) If it's nose mounted, and you ditched your AC condensor, I'd like to know how deep your 'cooler is.
Thanks!
I'm going air/air with the YS trim for now.
Old May 15, 2003 | 01:48 PM
MIGHTYMOUSE's Avatar
Default Re: Intercooler (inlet, outlet) pics???
http://community.webshots.com/photo/...64994904LLZsZA
no movement of the radiator, stock location
http://community.webshots.com/photo/...64994883BJplZm
http://community.webshots.com/photo/...64995285kKQqsl
requires removal of the wiper fluid bottle and modification of the hood latch bracket as shown
Old May 15, 2003 | 01:58 PM
1dirtyZ's Avatar
how can you get airflow to the intercooler and radiator in that position??
Old May 15, 2003 | 03:23 PM
LS1Tech Co-Founder
Nice pics, thanks!
I am planning to leave the same amount of room between the radiator and the stuff in front of it. My thinking is that is the stock spacing kept my 422ci nice and cool then it will work as well for the blower setup. Basically when I see people having cooling problems it's due to blocking the radiator or not running enough fan (CFM).
Old May 15, 2003 | 04:01 PM
zturbo's Avatar
Other turbo stuff...
John there is lots of pictures on my site of intercooler setups. You can also go to google there is some in there as well. IMO if you are going to run the ys at high psi like you are wanting I would run it in the front of your nose and get it away from the rad. I never liked blocking the air to the rad at all when i ran the turbo tech setup.
Steven
Old May 15, 2003 | 04:15 PM
99PTA's Avatar
nice pics
Old May 15, 2003 | 04:30 PM
LS1Tech Co-Founder
Thanks, I forgot about your gallery of pics.
I am NOT going to block the radiator, as I said, I am going to at a minimum retain the gap between the radiator and the stuff that would be in front of it.
I am planning to open up the front of the bumper cover as well but we are a week away from that so I am interested in looking at some setups.
Old May 16, 2003 | 01:37 AM
y2khawk's Avatar
http://harlan-engineering.com/eviltwin/FMIC/
I've got some more pics of the rad mounts and slight notching of the upper corners on the crossmember to clear the cooler.
moved the rad back about 2 inches, cut the corners on the upper crossmember, and clearanced the fan shroud for the water pump pulley.
Inlets run through the bumper core.
Old May 16, 2003 | 07:12 AM
oOoLy's Avatar
Sweet pics
