What pistons are people using?
Old Jul 19, 2007 | 02:36 PM
blu00rdstr's Avatar
Diamond: Great pistons for 25Kmi+ until a fixed boost leak over-boosted it.
Mahle: Brittle alloy, weak ringlands. Destroyed ringlands with some detonation, TSP motor lasted 35miles. A lack of expertise and knowledge by the vendor for suggesting 'thermal coated' (graphite) 4032 silicon alloy pistons for a 17psi motor.
I talked to JE, JE believes a larger top ring down space is important for strength with FI (valve relief results in a thin weak spot). They recommended against thermal coating because it flakes off in high-hp applications (ceramic coating doesn't expand/contract same as aluminum).
Wiseco has a beefy heavier cheaper piston due to forged side reliefs (not milled like others). I believe their top ring down space is larger also, at least their compression height seems taller than other brands. I'm building a 4.125 x 3.622 forged motor next, and although I do like Diamond pistons, for the size I need only Wiseco has off the shelf pistons available.
Old Jul 19, 2007 | 03:01 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Hmmm I have Mahles and they seem to be doing fine so far from what I can tell. For those of you who have had bad luck with them, which size did you get? I have the -4cc version, could I potentially have the same problem as the -12/-16/-32cc dished ones? Or is the bigger dish what causes the problem?
Old Jul 19, 2007 | 03:04 PM
1MEANGTO's Avatar
I have custom diamonds. in my opinion the pistons should be one of the strongest pieces of your build why use a cheap piston?
Old Jul 19, 2007 | 04:11 PM
cablebandit's Avatar
i think its the bigger dish....look at them sided by side for a 408
Old Jul 19, 2007 | 04:21 PM
ChevyChad's Avatar
Ahh gotcha... Wow, that is scary! I'm glad mine are flat top with just valve reliefs...
Old Jul 19, 2007 | 04:41 PM
ddnspider's Avatar
Originally Posted by cablebandit
not anymore...broke the ringlands twice with no detonation (approx 800rwhp...12deg timing 11.0a/f and c-16)...the area is THIN where the top land meets the piston. My wisecos next to it are like an anvil next to aluminum foil. these were 402 stroker/boost pistons. A Sponsor has had the same issue as well but i will let them tell their tale if they want
custom weisecos....
cable i thought u said u didnt have weisecos or hoped u didnt when we were talking in the other thread?
Old Jul 19, 2007 | 04:59 PM
you would be mistaken...or i was mistaken....i am very happy with the wisecos. They have already handled more misuse than they should have.
Old Jul 19, 2007 | 07:00 PM
slowbrakiller's Avatar
Originally Posted by ls1290
Diamond -15cc ( 4" bore x4" stroke ) with thermal coatings.
Keith
what is the thermal coating for?
Old Jul 19, 2007 | 07:03 PM
Drewstein's Avatar
JE here. You get what you pay for and a couple extra $$ in pistons is more than worth it.
Old Jul 19, 2007 | 07:05 PM
Tom@SpeedInc's Avatar
Diamond 11520 pistons, no complaints
Old Jul 19, 2007 | 08:12 PM
stevieturbo's Avatar
Who are the best people to get a set of Custom Wiseco's from ? Or just go to Wiseco direct ?
Old Jul 19, 2007 | 08:23 PM
  #32
topfig1's Avatar
Call LME for wiescos
Old Jul 19, 2007 | 08:36 PM
  #33
call Brian Nutter at wiseco..he is a member here as well...talk to him and you will know you are in good hands
Old Jul 20, 2007 | 08:19 AM
  #34
Might just do that
Old Jul 20, 2007 | 08:26 PM
  #35
blu00rdstr's Avatar
It keeps combustion heat from being absorbed by the piston. Combustion temperature is about 1200 degrees, and pistons are forged (and melt) at 950 degrees.
Mercedes experimented with carbon pistons and it improved power and emissions. (pdf)
Old Jul 21, 2007 | 12:35 AM
  #36
SiDeWaYZz28's Avatar
-31cc Je
Old Jul 21, 2007 | 12:58 AM
  #37
SuperZ's Avatar
Originally Posted by Josh @ KYTP
+1 for the above.
Mahle -16cc
I have these also.15psi and 50 shot from time to time for 2 years and no probs
Old Jul 21, 2007 | 10:16 AM
  #38
52172's Avatar
Probe turbo pistons
Old Jul 21, 2007 | 10:24 AM
  #39
E Wagz's Avatar
Diamond -22cc dish
Old Jul 21, 2007 | 10:30 AM
  #40
Navy David SS's Avatar
Wiseco, -22 dish
David
