turbo kit and motor
Old Jul 20, 2007 | 09:48 PM
stmz28's Avatar
Default turbo kit and motor
I have been looking at the aps twin turbo kits, the thing is a want a turbo kit that will put out around 800 rwhp, i do not have a bottom end but was looking at forded 347 engines i already have afr 205 heads. let me no what set up you guy are running that will not gave me to many problems. I want to build that power beacuse my freind has a turbo 2003 corba with 830 rwhp
Old Jul 21, 2007 | 09:15 AM
jegan1989's Avatar
man to be honest i would do a ironbloc 370 or 408 is what i would really do and with the ironblock with forged internals you wont have to worry about anything you will beat that little horse down to glue you will need new gears for your rear like a 3.42 because the 4.11 will most likely put you out of your powerband for the 1/4 mile other wise you will be fine if you need more help give me a call or pm and if you need parts let me know i will help you out
Old Jul 21, 2007 | 07:46 PM
stmz28's Avatar
I havebeen loking atTurbo Technology single race kit how is that one compare to the aps twin kit
Old Jul 22, 2007 | 12:26 PM
stmz28's Avatar
I have been looking at alot of different kits and it looks like alot of the twin or single turbo kits are lower than the k member or going under the k member have any had any problem hiting the pipes/ turbo on the ground and broke anything. if so what kits
Old Jul 25, 2007 | 12:58 AM
peter@aps's Avatar
Here's a link to the F body twin turbo pages, hope that helps.
Peter
http://www.airpowersystems.com/fbody/tt.htm
Old Jul 25, 2007 | 07:16 AM
smokinHawk's Avatar
a 346-370 can easily get you 800rwhp with the right turbo kit, im sure aps' kit with a small cube build would do it.
Old Jul 25, 2007 | 03:40 PM
z28adiction's Avatar
How much does the aps twin kit cost and how does it compare to ls1speed twin kit?
Old Aug 2, 2007 | 01:09 AM
peter@aps's Avatar
Browse this link when you get a spare minute or two, hope that helps you.
Peter
https://ls1tech.com/forums/forced-induction/668393-f-body-intercooled-twin-turbo-system-preliminary-pricing-5495-inc-free-delvery.html
