The idea of a blower sounds interesting but...
ARE stage 2 heads and cam (heads have dual springs)
LS6 intake
ARE ported oil pump
SVO 30lb injectors
SLP 85mm MAF
Ported TB
Whisper lid w/ k&n filter
SLP cold air induction kit(knock off of Fast Toys kit)
NGK-TR55 plugs
Ed Wright tuning w/ 28 degrees timing at WOT
RAM 6130/402 VDS clutch kit
Moser 12 bolt: 4.10 gears, 33 spline axles, HD Eaton Posi, --and T/A cover
BMR tubular Subframe connectors
BMR tubular Lower control arms
This set up dynoed 414RWHP 387RWTQ on a known conservative dyno and with AFS chrome 17x11 ZR1 rims w/ 315-35zr-17s.
I think 8-10 PSI would be sweet. Is this possible or do I have to change my H/C set-up? Should I just get the GWP stage 2 ATI-D1 kit? I am looking for some serious help here. Thanks guys!
Justin
Not only would it drive you nuts, but in order to fix it with no other problems you would have to dole out $1500 for a cog drive set up. The ATI units are very nice and i havent had any problems with mine yet
. It's a good blower and makes good HP.
