Purchased a Vortech kit now what ??
Old Jul 26, 2007 | 08:51 AM
URSLOW2's Avatar
Default Purchased a Vortech kit now what ??
A local shop had a great deal on a used Vortech Kit I couldnt pass up It's the V-9 g trim with the powercooler.Vortech Advertises 470 hp which is a good number but my goal is to be at 530-550 range. I have a 01 SS with 13k only mods are a lid and some kooks headers and OFY being installed this week. Ive already order a ASP 2.95 pulley and have the option to upgrade to LS6 heads and cam for a steal. Will this get me to my goal ?? and will a LS7 clutch hold this combination. Thanks in advance for you input
Old Jul 26, 2007 | 10:33 AM
HUGGER ORANGE SS's Avatar
Yes the Gtrim will get you to 530 to 550 Flywheel HP which is what they rate the 470 at. It can get you to 530 to 550 RWHP as well.. Depending on all the other mods needed, Headers, Exhaust Etc..
My buddy's Son has a 99 SS Stock with Pace Setter Headers and G Trim Making 11psi of boost.. He put down 565RWHP with that setup..
Be careful. With too much drag and spin up, he spun the damper on the crank because it was not keyed..
I always say to key the crank if your going to push over 500RWHP.. Never the less Always watch the crank bolt as over time they will work loose.. Happens all the time...
Clint
Old Jul 26, 2007 | 02:29 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah its just best to pin the crank with and ATI pin kit and that way you will not have any issues with it. I would also recoment a Racetronics intake pump with a MSD BAP and a set of #60 injectors if you are going to go over the 500rwhp mark. If you are going to stay under 500 then the inline fp will work. Let me know if you have problems I ran that set up for a few years.
Old Jul 27, 2007 | 12:08 PM
URSLOW2's Avatar
Thanks for the replies I just order the ATI pin kit Is it worth swapping to a set of LS6 heads and cam or should I go with a little larger cam ???? any Recommendations and my goal is 530-0550 rwhp
Old Jul 27, 2007 | 12:50 PM
Websy21's Avatar
I'd say jsut run your stock heads if I were you and get a blower cam. I got a comp 224/228 .581/.588 114LSA. If you get some good flowing heads you would be over that barrier and might even reach 600rwhp with 10psi. I think that starts hendering you stock internal limits obvioulsy. With a similar cam I mentioned on 8psi boost you would easily reach that goal, have nice drivabilty and still retaing reliabilty, depending on your foot of coarse. You have a 2001 right because if you do you already have the LS6 heads and cam
Old Jul 27, 2007 | 01:31 PM
No Juice's Avatar
Trade it in for a Procharger kit
Old Jul 27, 2007 | 01:36 PM
mbrownin's Avatar
That is incorrect. Those 2 things are the bulk of what makes an LS6 an LS6.
Old Jul 27, 2007 | 01:52 PM
URSLOW2's Avatar
My first choice was a Procharger D1sc kit but their was a killer deal on a Used Vortech I couldnt pass up
 Michael S. Palmer
Old Jul 27, 2007 | 02:08 PM
LebaneseShowoff's Avatar
The only LS6 thing it may have is the Intake Manifold. And that's about it.
Old Jul 27, 2007 | 03:09 PM
Websy21's Avatar
Sorry my bad, not sure what I was thinking there
Old Jul 27, 2007 | 03:32 PM
mbrownin's Avatar
Brain fart
Old Jul 27, 2007 | 05:46 PM
Websy21's Avatar
You got it! Hey man where did you get that smily, thats awesome
Old Jul 27, 2007 | 06:00 PM
mbrownin's Avatar
It's right here on ls1tech.com! If you use the quote button to post a message, then press "[More]" underneath the collection of smileys, you get a new window full of other smileys. It's on there somewhere. A little over half way down on the right side.
