procharger fan help
Old Aug 3, 2007 | 09:43 PM
02NBMFormula's Avatar
Default procharger fan help
Just got done putting the procharger single fan on the car and have everything wired up correctly (i think). currently, it doesnt have the blower on it (waiting on buddies lift to open up). so after i get it installed i test it with my fan switch, works fine. start the car up, back down the ramps and let it idle for awhile to see if the fan kicks on, it gets up to 180degrees (still have a predator lieing around so its more accurate than the factory guage) and the fan doesnt come on, yet im able to use the fan switch to turn it on, so do i need to adjust the fan settings or what (have hptuners)
thanks
Old Aug 4, 2007 | 09:28 AM
anyone??
Old Aug 4, 2007 | 09:38 AM
Superman09's Avatar
LS1Tech Sponsor
Well if you have the stock thermostat, i dont believe it will kick them on yet, i think the stock setting it higher than 180, not 100% sure though
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Aug 4, 2007 | 03:15 PM
ty_ty13's Avatar
7 Second Club
thermostat has nothing to do with it... check out your system setup in hptuners and see where the fans are set... it may suprise you..
Old Aug 4, 2007 | 05:35 PM
yep, thought it was lower, feel like a dumbass right about now
