PT98/88 on a 347?
Old Aug 16, 2007 | 04:23 PM
NA$TY-TA's Avatar
Originally Posted by DrTurbo
...certainly
Ready tomorrow???
Let me know when you have recieved my box.
It should be coming from VA Speed.
Kyle
Old Aug 17, 2007 | 04:32 PM
DanZ28's Avatar
Sent an email yesterday to forced indutions with questions about turbo choices very similar to the thread starter's setup.
Will the S88 and S91 be more of track only type of turbo? What RPM could you see full spool typically with those turbo's and the thread starters combo?
Old Aug 19, 2007 | 03:51 PM
PHIL H's Avatar
Well, i found one finally and i think i did ok...101mm turbnetics ball bearing with a 1.0 A/R and a F Trim wheel. Has 15 runs on it and the compressor housing is polished and the hotside is coated black. Got a smoking deal on it too!! Man those things are $$$ new...
Old Aug 19, 2007 | 04:43 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Sweet, what are the dimensions of the whole thing?
ALLBOTTLE's Avatar
LS1TECH Sponsor
101mm on a 347
Old Aug 19, 2007 | 04:46 PM
NA$TY-TA's Avatar
Should be fun......
Old Aug 19, 2007 | 07:30 PM
PHIL H's Avatar
Originally Posted by Alex @ CMS
101mm on a 347
Why not?? Alot of the Ford guys do it with smaller engines...Although now i believe i am going with a 4 inch crank so it will be a 383 deal.
PHIL H's Avatar
Originally Posted by NA$TY-TA
Should be fun......
I hope so....
Old Aug 19, 2007 | 07:38 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
That sounds more like it...
Thats true but the advantage the ford guys have is 15+ years or R&D to get them down the track. 450+ CMF heads help too.
How high do you plan to turn the motor?
Old Aug 19, 2007 | 07:50 PM
PHIL H's Avatar
I dunno PSJ..I would say its LARGE by HUGE though!!!! I will measure it when i get it though..
Old Aug 19, 2007 | 08:09 PM
PHIL H's Avatar
All these engines are just dumb air pumps anyway..I dont buy into the big flowing heads in a turbo application.. Brad Brand ran 7.15 @ 200+ with his single 106 360-380 ci with old TFS high ports, and then built a new engine that was 420 ci with big bad Neal heads etc...Guess what, it ran almost the same if not worse..Brad is a very sharp guy and knows his stuff so i am sure there was nothing left on the table.
Old Aug 19, 2007 | 08:46 PM
  #32
ALLBOTTLE's Avatar
LS1TECH Sponsor
It's just a bit more complicated than that...lol
Ultimately the turbo is the restriction in the application, It can only move so much air, but what big heads can and will do is give you much greater area under the curve.
What ECU are you going to use?
