Saturation Intercooling
Old Aug 17, 2007 | 10:12 AM
Twin76mmTA's Avatar
Default Saturation Intercooling
I was thinking about using saturation intercooling with methanol instead of a A2W intercooler.
The car runs 8 Primary 120lb injectors with a BFP of 30psi and a 2:1 Rising FPR
I was thinknig about using a setup similar to this with 4 160lb injectors spraying 100% Methanol, either spraying at the same time or having the system turn one on every 5psi.
Any feed back would be appeciated,
Motor is a 408 Allpro Heads, twin 76mm, BS3, Solid Roller
Old Aug 17, 2007 | 10:24 AM
anarchy99's Avatar
if it works, you'd save alot of weight. Intimid8 would probably be able to help since he's running staged fuel injection on his car with great results.
Old Aug 17, 2007 | 10:43 AM
smokinHawk's Avatar
i think brady had a setup like that, or something. i remember an intake done like that cant remember if madman did it or someone else.
