Pro's and con's of running COgs on the street
Ive got about 300 miles on the setup now with no real problems. I think the 2 most important thing to running the cog setups is to have the Big block hub from ati so you dont split the thinner one at the keyway, as well as having plenty of bypass volume to keep the pressure out of the piping and resisting compresser surge. Ive got a single mondo currently and have been contemplating the addition of another or stepping up to a larger tial for safetys sake, although it seems to be doing ok right now as is.
I think people all want to say how cogs are so bad and whatnot, although nobody ran them themselves to compare. I really like mine and have had no issues.
Dont forget that cogs put less lateral stress on the crank because you dont have to tension them as much as a belt
I'm running a cog setup on my car, but I only have about 500 miles on it right now.
Edit: The downside to running a cog on the street is belt life. The cog belts wear out/break/rip teeth off faster than what a serpentine belt would wear out.
For you and cjmatt - how's the noise compare to a ribbed? I have a sleeper (though it is still too loud an exhaust note) and do not want a 'gear drive' type whine from under the hood.
Thanks,
Jim
anyway.... the big thing is belt life... the life changes wildly, but i dont know anyone running one that lasted over 3000miles without having rounded teeth.. most of the guys i know running them have roots blowers.. but the wear and concept is the same..
btw, price the belts first.. they SUUUUCK to buy. LOL.
Thanks,
Jim
One thing I dont understand is how people get such short life out of the belts though. Plenty of cars come with timing belts which go 50k miles before there even supposed to be changed, why wouldnt they last as long on a supercharger?
And as far as price goes, youve just got to look around, Ive found some pretty good prices online, 30 bucks a belt....which is fine for me even if i have to change it every other oil change. Nobody said itd be cheap to drive 7-800hp cars on the street
Can't tell anything at highway speeds.
