Anyone Have Any Experience with a GT4202?
Thanks for looking...
If not id put it up front....... there is room.
That turbo will do 550rwhp on a 346 no problem... now down th eroad it depends on if ya stay with stock cubes and how hard you really push it...
Is it the 70 or 74mm compressor wheel??
Here's a link to the turbo: http://www.turbobygarrett.com/turbob...2_731376_2.htm
I believe the 02 designation makes it a 102 mm... I think that's what it says for the compresor wheel diameter. Anyone think any different?
BTW, I am staying stock cubes for now.
Speaking of turbos <$1000, what have you heard about Master Power?
I had a master power temporarily before getting a few garret units. They seem to be a hit or miss. Some have great success and others dont get much out of them. I think a lot of shops will recommend something else. I have a .96 MP exhaust housing and thats it, so I can't comment on their performance. It worked fine on my 60-1 turbo but thats all the data I can give. Their construction is relatively solid but not to the specs of a garrett, turbonetics, ect. I ended up selling mine in favor of a garrett 67
I personally don't think you'll get the power you want out of it once you push it past 8 or 9 psi.
And FWIW, the 102mm designation is the exducer diameter of the compressor wheel. Similar for the 94mm of the GT4294. Based on the wheel trim for each that's 74mm and 70mm inlet diameter respectively.
http://www.forcedinductions.com/productturbonetics.htm
What's the difference between the TC and T series turbos?
