should i coat the pistons or not?
do I need to coat the pistons? its fairly expensive and I can use the money elsewhere but if i need to do it i will
Mahle are side coated, if you order them coated from the manufacturer it's only more for 20-30ea, an extra 200-300 isn't bad for the insure not to mention 200-300 when your are spending several thousand won't make much of a difference.
