Blower Belt PN
Old Aug 27, 2007 | 07:12 PM
Black_Z28's Avatar
Default Blower Belt PN
I have a Vortech V-9 SQ G Trim blower in my 00 Formula. I blew a belt recently, but all I could find was a 6 rib belt. So, I threw that on there in a pinch. Well, I've noticed that I'm not getting the same boost numbers as before, so I assume I'm getting some belt slippage. Anyways, I thought the belt PN was a 8055, does that sound right? I don't have the car right now, because I'm rebuilding the tranny, otherwise I'd just look at it.
Any help would be great.
Thanks
Old Aug 27, 2007 | 07:37 PM
DeltaT's Avatar
What 6-rib did you find that fit? If it was the right length, post the number here and I should be able to tell you the 8-rib#.
For example, Goodyear belts are measured in inches and mm.
My 8-rib is a 4080670:
8 means 8-rib
0670 = 67 inches. A 0675 would be 67.5".
The 6-rib would be 406xxxx, with xxxx=length in inches as above.
My 0670, 67 inches = 1702mm, and that's usually on the belt somewhere too.
Any shop that stocks the brand should be able to order them quickly.
Also, Dayco belts use a 5 in front instead of a 4. Other than that, the P/N is the same as shown above.
Jim
