Magnuson dyno question
Damon
We didn't have our dyno yet when his car first came in, so we didn't get a baseline, but stock LS1 F-body's with an M/T usually see 300-325 RWHP.
SS125, I snet you an email with the requested information.
Ed
That's all I got until the oil consumption issue is done.
As for the video. Did you get a chance to run the car without the lid on ever. Good god is the blower rediculously loud!
Ill let you guys know when it gets dynoed chances are i will post in the dyno section ill try to remember this post tho.
Kyle
I did a leakdown test twice and Ed has done it twice once after the build and once while checking my work, I rerouted the PCV to a catchcan and vented to atmosphere, replaced valve seals, checked the blower's seals and gaskets (not much to check). I have fouled out at least 10 sets of plugs, and god knows how many quarts of oil. If I go into boost I start eating oil quick. Its gonna be my bottom end but I starting from the outside to make sure it was not something else, working our way down from the top end to the bottom. Hate to have it pulled all apart to find out it was something stupid up top, but I got a feeling its in the bottom end. It had new rings and bearings put in as well and was brushed. It did not start doing this until after the build. I just hope we find it soon this is killing me. I may may not see the numbers he is getting but we figure I should be up around 530 or so on the HP when I get it all figured out.
Ed
. At what Psi are you running BTW. Though your graph showed I can deff hit the 550hp mark I wanted
