Got my STS in
Old Sep 6, 2007 | 03:18 PM
rojows7's Avatar
will do mods r in second post
Old Sep 6, 2007 | 06:22 PM
candlelit's Avatar
I have nearly the same setup as you, Comp Cams 224/228 .581 lift, ported 241's, except I don't have the FI. But I'm thinking about it. Throw some pistons and rods in mine and I might consider it. Is your shortblock stock? How does it feel from NA to same setup + 5 PSI?
Old Sep 6, 2007 | 09:38 PM
rojows7's Avatar
internally im still stock but i got comp 921 springs,lifters still on stock rockers though...imma start bulinding a forged shortblock soon though so when my stocker pops it'll be ready..looking to build a 6.0 block with 9.5:1 compression and some afr heads and maybe a more radical cam like 242/246 with 115 lsa to make up for the lost compression
Old Sep 6, 2007 | 10:56 PM
candlelit's Avatar
that would be sweet, with the 6.0 and larger cam. I actually found myself a good buy tonight on a forged 347 shortblock and will be picking it up sometime within a couple of weeks. The pistons may give me a higher compression than what I want (forged -4cc), but they should do I haven't decided yet if I want to change cams, springs, & heads or not.
Old Sep 9, 2007 | 10:00 PM
rojows7's Avatar
well the dyno results are in...450 rwhp 416lbs tq..dont know about the torq..but 450 rwhp at 6000rpm with some high IAT's...no intercooler or meth at 5psi..****** awesome thanx to my mechanic simon and my tuner Charlie from A&A corvette...if not for the high IAT causing the computer to pull some timing at the end of the powerband 460 or 470 would have been had...cant wait to dyno it w/ 7-8 psi 500rwhp+ here i come
Old Sep 10, 2007 | 12:20 AM
rojows7's Avatar
still wondering why torque was so low???any ideas tuner said something about the IAT's
Old Sep 10, 2007 | 07:40 AM
ZL1Killa's Avatar
Originally Posted by rojows7
any good websites where i can pick up some exhaust wrap???
uh... advance auto parts or autozone... I believe DEI makes it or something like that.. and they have silver and black coatings you can spray on the wrap that i believe is supposed to make it last longer.
you will need 3 cans of spray (whatever color you want, i did black) and 2 50foot rolls
