Nitrous or Methanol
Old Jan 26, 2008 | 11:02 PM
DeltaT's Avatar
I would run a wet nitrous system jetted for methanol on a separate fuel system.
I've got this setup about half installed on my car (it's a dual Big Shot plate above a Super Victor), but the 3-gallon cell is also going to feed an FJO Racing alky injection pump and system for off-nitrous/on-boost (normal) use.
I'll look it up tomorrow, but IIRC you need to pump 2.3 times the amount of meth with the same nitrous jet that you would normally run with gas to get the right mix. If you call NOS they will tell you the correct jet size for a 75 wet shot with meth. They'll want to know what fuel pressure you are running for the meth.
Jim
Old Feb 1, 2008 | 10:49 PM
BOOSTED1995's Avatar
Thanks Delta.Anyone with the sys installed have any feedback?
I would like to run a 50hp single fogger nozzle in the boost tube with meth.
My meth pump runs at 100psi
