not sure where else to put this....
Old May 30, 2003 | 03:51 PM
SRV's Avatar
SRV
Default not sure where else to put this....
since it did say turbo/super on the forum description, but anywho. would the free ram air mod and the ram air hood/kit be able to be utilized on the same car? or would going to the ram air hood require a reworking of the intake to the point where the free ram air mod would have to be removed/reworked.?
SRV
Old May 30, 2003 | 04:23 PM
2001CamaroGuy's Avatar
Default Re: not sure where else to put this....
should have gone in the "external engine" page but anyways....
I suppose this is an F-body with a factory style air box. Then you cut the bottom out to make the free ram air mod (am I right?).
"IF" the ram air hood uses the factory style air box (most do), then you will get both the "ram air" of the hood and the "free ram air." If you are going to a true "ram air" hood (not an SS hood), then the "free ram air" is no longer needed.
follow?
Chris
Old May 30, 2003 | 05:14 PM
SRV's Avatar
SRV
rocking, thx.
SRV
