Waste gate vlv
Old Sep 10, 2007 | 09:05 PM
Purrvert's Avatar
Default Waste gate vlv
Just installed a BOV to FMIC. Started thinking, know that's dangerous. Why do we operate the waste gate from the manifold pressure? When we reach set pressure the waste gate opens and allows the exhaust to bypass the turbo, we get off throttle to shift and seperate the waste gate from seeing the turbo pressure. Would it more efficient to tie the waste gate hose before the throttle body? Anyone experiment with this?
Old Sep 10, 2007 | 09:37 PM
Subliminal Hit's Avatar
its supposed to be before the throttle plate. look here www.tialsport.com and click on technical then wg install diagram
Old Sep 10, 2007 | 09:40 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
We are talking fractions of a second here, but with the wastegate referenced to the manifold, it closes as fast as possible when the throttle closes and causes manifold vacuum. If it were referenced before the BOV, it would take some tiny amount longer to close the wastegate, so in theory it would take longer to respool. I think you would be hard pressed to actually notice the difference.
Old Sep 10, 2007 | 10:11 PM
Purrvert's Avatar
Thanks, makes perfect sense to me. My STS install calls for the waste gate to be activated from the brake boost line that comes directly from the intake manifold. Gonna move it to the other side of the throttle blade.
Old Sep 11, 2007 | 10:19 AM
MIGHTYMOUSE's Avatar
if anything you will only notice slower boost recovery from the shift
