Engine swap question.
Old Sep 13, 2007 | 11:45 AM
Firechikn's Avatar
Default Engine swap question.
O.k. I know wrong section but the other one is not getting any replies. Are there any ground wires that connect to the back of the passenger head? The car is doing some crazy things and I feel like I missed one somewhere. I've got the 3 ( 2 bolts ) on the driver head, but I can't remember if there are more. I can't see any coming out of the harness, but you can't really see much. Thanks.
Old Sep 13, 2007 | 11:47 AM
Firechikn's Avatar
Oh yeah, 02 TA. oops.
Old Sep 13, 2007 | 11:57 AM
Inspector12's Avatar
TT-TECH Veteran
Grounds Two on back of drivers side head one on drivers side of the block right behind the Alt. Ground strp going to the fram rail both 10 mm one on each side of the Head light assyemblys and one one the drivers side strut tower and then the Bat ground on the passenger side strut tower. In side the car there are a couple on each end of the dash right behind each one of the kick panels. One under the drivers side seat (FP ground). That is all I can remember right off the top of my head. The ones on the back of the drivers side head is the ground for the fuel injectors and a PCM ground. Good luck.
Old Sep 13, 2007 | 12:01 PM
Firechikn's Avatar
Cool. I was hoping I didn't miss one on the passenger head. Thanks.
