Help with supercharged plug gaps!!!
Old Sep 14, 2007 | 09:31 AM
fordkiller's Avatar
Default Help with supercharged plug gaps!!!
What's a good spark plug to use for a 96 LT1 with a Vortech supercharger (6-7 PSI boost) and 42 pound Motorsport injectors? Other than headers and better exhaust the rest of the car is stock. I just put in NGK TR55IX's (part 7164), gapped them at .044 and the car runs great cold but when it warms up and I get on it the car spark-knocks like crazy and occasionally backfires. The NGK's out of the box and the stock Delco plugs I took out were at around .060 gap. The car ran great with the Delcos, I just changed them over to the NGK's per the tuners advice. (I got a mail order tune on it for the 42 pound Ford injectors and to raise the rev limiter to 6500). Any help would be apprecitated! I see plug gaps ranging from .032 all the way up to .060 on these cars.
Dave
Old Sep 14, 2007 | 09:42 AM
02NBMFormula's Avatar
most ls1 fi cars run tr6 plugs, they are one step colder than stock and gaped at .035
Old Sep 14, 2007 | 10:41 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
You need a plug that is 1 step cooler than stock. Your gap is way too big also. You need to be in the .030 to .035 range. TR6's @ .035 is a good combo.
