Red Carpet Turbo Kit ????
I will definitely shop around for the right system and tuner.
I'll check back when I get stuck and have questions.
Definitely, want something I can use on the stock engine but is upgradeable to work with a built 408.(long term plans)
Wow, JAvenger007 You got your hands on a W-30! Nice.
Synergy (sponser --->) is one of the best and it would be approx $500 (call them for exact price) total for a complete tune.
They have done many turbo cars as well. You may want to talk to them for advise or even about fabbing a custom kit for you which they do.
And Thanks ninetres, JAvenger007 and njc.corp for backing me up. I'm really here to help as much as I can and i'm really a good guy
Just looking out for the guys interested in going FI.
heres it after a wash last weekend. only 1k miles on motor since being rebuilt (the original 455). Just happened to find a guy that didn't realize he owned a show car and sold it for 10k less than its worth
Unless I read your post wrong...
I give up I can't win, when I agree with you guys you still come at me
now the guys mate on here that got the 'fleabay' kit or whatever you guys are calling it got it VERY quickly! also its was all stainless, the PTS kit is mild steel.
so ok you have to swap the turbos for somthing better (most guys swap to bigger turbos pretty quick anyway! lol) and you dont get instructions and a few bits and bobs. its a hold lot cheaper than buying form PTS and a lot easier than bullding your own kit! and im not even going to mention cost!
my opinion is not form first and dealings with either company, its just what i have been told!
thanks CHris.
-Your choice of TC70, 72, or 76
-Alternator Relocation Bracket
-Turbo Blanket, Oil Lines, V-bands, Tial BOV and WG
-Intercooler and piping
Then just leave it up to you for fuel, PCV, and option of having scavenge pump or just returning to the pan.
I am willing to help you out anytime if you have questions you have anytime, just send me a pm.
What you really need to determin how much HP you want to have when its all said and done. I am happy with 508 RWHP or so and my LS1 is totally stock so I am going with the APS kit, its a steal at the current $5495 price free shipping.
If you are going to run much more than a 383 CI engine then you might want to wait till APS comes out with their upgraded/bigger turbos. I've heard alot of good about the speed inc kits also, and they already have the bigger turbos which will work better for 383+CI engines.
Just look at your bankroll, your HP goals, and whether or not you are going to install and tune it yourself and find the best kit for your needs.
If you would like better information from the great guys here it will help if you give them more info on what you are looking for.
I know its hard being a newb,
Good luck finding the right kit.
Fil131
Ya, I have thought about HP goals, budget. Think I have a fair grasp now on the systems out there, how to install them, what can and can't be done.
Right now I am looking at intercooler options. I do not want to butcher the car like some do cutting out chunks of the front bumper or removing fog lights to get it air. Also not familiar with the air to water option.
This is next years project but I am doing my homework now. Basically I want to boost the stock engine but then have a system that can accept more boost later when I build an engine for it. That really just means changing the springs in the BOV and wastegate right? (I know tuning as well)
Also trying to figure out where to mount the guages without removing all the dash vents.
Also I see some turbos are oil and water cooled so trying to learn about the water side of that.
Of course you can always have a whole system fabbed but it will take alot of time.
The intercooler is a huge plus with this system as well, it fits right in without cutting huge chunks out of your car, and promotes direct intake flow with its upward flow design.
Just to give you some info 1 FMIC is better than 2 seperate smaller intercoolers, and water to air just helps to cool and densify the air better (may only add a few more HP and TQ per LB of boost).
To higher boost you will just have to dial it up with your boost controller, the bov doesnt have to be changed in any way unless it is not able to flow enough air to prevent backflowing air to the turbos.
The springs in the wastegates set the minimum boost you can run. If you use 3lb springs then the wastegates will allow no less than 3lbs of boost to reach your turbos.
The boost controller whether you use electronic or mechanical is what you set the maximum boost with, and can dial it in to whatever boost level you want either under the hood or in the cabin depending on models.
The LS1's dont really offer much for guage mounting, A-Piller is usually the best/easiest option, or you can find somewhere to hide them if you want.
Turbos are basically oil lubed and water cooled. I dont know if I can explain it more that should sum it up for you. Look for water cooled they will last longer and help with keeping the boosted air a bit cooler, the water cooled turbos also do not require turbo timers in most cases.
Hope this helps.
Fil131
I am not sure if anyone makes the A pillar guage pod for a convertible. If so I would love to see the link. I like the look, my only concern is it tips the cops off to pop your hood. Only other spot I can think that would look decent is in the glove box.
With the air to water, I am just not sure how to route them. I see talk of the water chest mounted in the trunk.
As for the water cooled portion of the turbo, do you tap into the rad?
Unfortunately I can't do the APS kit right now. Having decided to keep both cars (an expense in itself) I have a lot of projects in the works on both of them as we speak. Not to mention the wife and kids. What's funny is I see guys selling their cars when that happens and here I am buying another
Also, I see that APS has an upgrade option to larger turbos.
My turbo project should be on the road at the same time my twins are born. Might bring'em home in it. I pieced my kit together- 6.0 truck manifolds and a crossover from another member on here. Still have to build the DP, but I have less than $400 in the hot parts right now; just to give you some more options.
