Bad heat soaking on upper intake piping
Old Sep 26, 2007 | 08:27 AM
SSblack98's Avatar
Default Bad heat soaking on upper intake piping
Anyone know what would be good to wrap the upper intake pipe on my OFI kit to keep some of the heat out of it? Guess it needs to be reflective type material. Haven't seen anything yet that looks like it will work very well. Header wrap would just hold heat in the intake piping I would think. Turbo sits right below it and it gets hot as ****!
Old Sep 26, 2007 | 07:07 PM
SSmokin 01's Avatar
How about this?
http://www.jegs.com/webapp/wcs/store...0002_595997_-1
Old Sep 26, 2007 | 08:49 PM
DeltaT's Avatar
Or this other Thermo-Tec product:
Or this:
I've thought of these but I noticed after a good run my piping is cool to the touch - I just think when the bypass closes the entire plumbing gets cooled pretty quickly. I can see in my logs that the IAT drops.
Jim
Old Sep 27, 2007 | 03:48 PM
SSblack98's Avatar
Thanks I will check them out. After a run spraying meth you can touch the pipes but after idling for a bit or slow driving you cant even hold your hand on it!
Think I will try wrapping it with header wrap and then covering that with the heat reflective tape. See what happens
Old Sep 27, 2007 | 08:04 PM
DeltaT's Avatar
Hey, the worst that can happen is a huge explosion, eh?
Sounds like a good plan...
Jim
