Can I use this heads/cam with a SC?
Old Sep 30, 2007 | 06:20 AM
kendo347's Avatar
Default Can I use this heads/cam with a SC?
I have a Comp Cam 224/228 581/588 112lsa +4. Absolute Speed Stg 2 5.3 heads with crane duals yielding I believe a 10.8-1 compression. I currently make 409 rwhp, 405 rwtq and would like to get that up to 500. Hopefully I can use these.
Old Sep 30, 2007 | 06:24 AM
dugo's Avatar
you schould be able to u a sc with that combo..but if i were you i would probably go with nitrious... its cheaper easy to install and youll get more power.
Old Sep 30, 2007 | 06:34 AM
kendo347's Avatar
I used to run a nx kit with a 125 shot. Too much of a hassle to remove the bottle, drive 25 miles to get it filled, heat it etc. I need power on demand!
Old Sep 30, 2007 | 06:46 AM
EPP's Avatar
EPP
With an ATI ProCharger you won't need to run much boost to get you to your goal, easily done! Bob
Old Sep 30, 2007 | 06:52 AM
dugo's Avatar
understandable.. its easy for me i have a bottle warmer on it and the shop with the nos is 2 mins from my house soo its good for me.. dude dont get me wron a s/c hands down is awsome..
Old Sep 30, 2007 | 06:58 AM
kendo347's Avatar
Bob, can I run my current heads and cam with it. I really do not want to swap them. I know the say you want 114-115 lsa but if i can I would like to keep the one i have. Thanks, Ken
Old Sep 30, 2007 | 07:04 AM
EPP's Avatar
EPP
Smile
Yes, you can use them. You won't need much boost to meet your goal, and they will work just fine. Bob
