Need Help On Deciding
Old Oct 3, 2007 | 07:24 AM
96 trans am's Avatar
Exclamation Need Help On Deciding
Hello everyone,
I have a rod knocking now and plan to do a complete rebuild and go FI this time. I have a 99ta a4. I plan to buy a 370 from LME and put a Procharger D-1SC or F1a on it. I know this is not going to be a cheap build and I assume its going to be around 12-15k. Can someone give me some pointers on what type of heads I should use, I've heard alot of people using the ls6 heads. My goal for this is to be 600+rwhp. I'm just not trying to build something and spend alot of money on and then want to rebuild it a few months later because I could of did it better. I would like to know what kind of fi cam i should use, injectors, fuel system, and other parts I need. I'm also out of san diego, so does anyone know any good shops around there to build the car. Any input would be greatly appreciated.
Thanks
David
Old Oct 3, 2007 | 07:59 AM
njc.corp's Avatar
heads- etp,allpro or afr-
Old Oct 3, 2007 | 09:13 AM
Websy21's Avatar
Ported LS6'ers would do the job but I'd go with ported 6.0 heads/317 heads to lower compression and turn up the boost
Old Oct 7, 2007 | 06:29 AM
EPP's Avatar
EPP
Smile
Originally Posted by 96 trans am
Hello everyone,
Thanks
David
Check out what we did for this build that resulted in 740 rwhp.
http://www.exoticperformanceplus.com...Car.php?car=40 Bob
