made some shake down passes last night
Old Oct 6, 2007 | 10:56 AM
LittleRedZ's Avatar
Default made some shake down passes last night
Well first time out with the car and have to get used to everything. I was having some issues with my Ratchet shifter and traction of course.
I tried flashing the converter and the car leaves real lazy with a 1.55 60ft, i let out early cuz i still have no cage in the car. Last pass is the only decent pass i made. I decided to leave on the T/B build about 12psi off the brake and blew the tires off big time, let out got back in it hooked shifted in 2nd, and didnt feel the tranny shift so right away i though i was in between gear so i pulled it again and realized about 2 seconds later that it was 3rd gear so i just stayed in it.
60 1.91
330 4.57
1/8 6.79
mph 111.3
1000 8.68
1/4 10.26
mph 143.06
The car is tuned rich, 10.X a/f havent played with the timing or the alky yet so i need to get a Wide band for Gen 7 and log it next time out and start making correctins, thats if i can get the suspension to hook on the T/B. Oh yeah shift light i need one of those also
What do you guys think i'll pick up actually hitting second gear mph wise? My guess would be at least another 5mph.
Old Oct 6, 2007 | 03:49 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Car should pick up all over, you are off to a great start... You've seen a number of folks like myself run 9.1-9.4 with 143-145 traps so if you can hit 145-148 hooking you've got a low 9 car with no other changes other than traction and adjusting your shifter linkage.
Old Oct 6, 2007 | 05:09 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Yeah, it picked up pretty nicely on the top half. Get a cage and let her rip!
Old Oct 6, 2007 | 05:20 PM
Schurters LT1's Avatar
60 1.91
330 4.57
1/8 6.79
mph 111.3
1000 8.68
1/4 10.26
mph 143.06
sick ....what are the spec on your cog set up...
Old Oct 6, 2007 | 05:42 PM
Z8'S's Avatar
Very Nice for the maiden voyage!!!!
Get it ready for the LTX shoot out in April !!!!!
Old Oct 6, 2007 | 05:53 PM
kp's Avatar
kp
http://lsx.streetfire.net/video/1A3F...9911FC1EF9.htm
No 2nd gear (broken sprag), 6.50 @ 106.xx
The next weekend after fixing the trans it ran 6.10 @ 110 at the same track in similar weather changiing nothing but fixing the trans, 2nd gear does help quite a bit
Old Oct 6, 2007 | 08:00 PM
LS1 SPEED's Avatar
nice...that car is going to run hard with a clean pass.
congrats
Old Oct 6, 2007 | 09:23 PM
Websy21's Avatar
Get that bitch to hook, hello low 9's
 Michael S. Palmer
Old Oct 6, 2007 | 10:14 PM
LASTLS1's Avatar
6 Second Club Moderator
Nice mph, it should run well. Get that 60' down.
Old Oct 6, 2007 | 11:07 PM
LittleRedZ's Avatar
Z8s bracket and tensioner, 86 tooth crank and 30 tooth blower, 36mm polychain Carbon GT belt(loving this thing btw)
Old Oct 6, 2007 | 11:09 PM
LittleRedZ's Avatar
i see what i can do, i think the set up is going to change a little by then
Old Oct 7, 2007 | 12:56 PM
pm me your number bud...i would like talk about our combo
Old Oct 7, 2007 | 07:11 PM
LittleRedZ's Avatar
thanks guys im going to fix that shifter and tune the suspension some and see what i can do this coming friday, then its time to do some tunning and pick up some more power
Old Oct 7, 2007 | 07:17 PM
hellbents10's Avatar
LS1Tech Sponsor
wooohhooo, she has the mph, should be a flyer!
Old Oct 8, 2007 | 04:00 PM
67Firebird455's Avatar
LOL wow, 1.9x and low 10's at that mph, you have a real sweet rocket there man.
