D-1sc
Old Oct 7, 2007 | 12:50 AM
98BlkFormula's Avatar
Default D-1sc
I just bought this kit but b4 i install i have some ?'s. Can i run this kit on a stock fuil pump, injectors? if so what kind of hp will i see. my car(98 Formula) is for the most part stock all i have done is headers and magnaflow catback and thats all. should anything be upgraded b4 the install. Any input is appreciated
Old Oct 7, 2007 | 06:05 AM
EPP's Avatar
EPP
No! You need larger fuel injectors and a higher flowing fuel pump.
This list that I put together may help you out.
http://www.exoticperformanceplus.com....html?item=540 Bob
Old Oct 7, 2007 | 07:01 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
You can. But only if you want to blow your engine up. It will be a big kablamo!
Old Oct 8, 2007 | 01:12 AM
revturbo's Avatar
you have to have the seimens injectors and a larger fuel pump and a tune. then depending on the boost you run you'll see about 450 at the wheels at 8lbs.
Old Oct 8, 2007 | 08:29 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I ran an inline walbro and 42# injectors with my P1 setup on the stock engine and that worked good up to 489rwhp.
