Procharger dimensions
Old Oct 7, 2007 | 02:29 PM
thumpstick's Avatar
Default Procharger dimensions
I posted a thread not long ago about supercharging my ls1 rx7. I need the dimensions of the f-body procharger. I'm not sure if there is a difference between the physical dimensions of the p1sc and the d1sc, and I'm not sure which I will be using so I'll need to know the sizes for both . I need to know how far foward it comes (from the front to the alternator pully to the front or the inlet). I could also use the width, but it isn't as important.
thanks,
-John
Old Oct 7, 2007 | 02:39 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
The P1SC and D1SC are the exact same size. Only difference is the internals. I don't have a P1 anymore, so I can't help you out on any measurements...
Old Oct 7, 2007 | 03:39 PM
thumpstick's Avatar
Thanks, I figured that was the case but I wasn't sure.
So, to simplify, would someone with either a P1SC or a D1SC on an fbody mind measuring the length from the front of the alternator pulley to the front of the inlet?
Thanks again
Old Oct 8, 2007 | 11:22 PM
thumpstick's Avatar
will someone help me out here?
Old Oct 9, 2007 | 05:09 AM
EPP's Avatar
EPP
Smile
My car is currently up on one of our lifts, give me a call this morning and I'll get measurements for you. 260 244-4808. Bob
