Time to go FI...got some questions...
ATI D1-R kit starting at 8psi
Stock block (for now)
P&P 6.0 heads to lower comp. ratio
I am needing advice on a good cam...maybe like a 220/220 .560 .565 114lsa??? I really have no idea on blower cams.
Soo guys let me know what you think!
TireFryer
Get 42.5LB injectors..
I would go with TEA's 6.0L 73cc chamber head, with a stock block that will put you a little under 9.5:1 compression I believe....you won't see 8psi with the kit, especially if you have headers...
I have a 214/218 .540/.550 114lsa cam that I'm going to use in my 372 bore motor...I used that w/my stock block as well..
I had LT headers as well...
I saw a total of 4psi...
I also meant the D1-SC, I dont know why I said D1-R, not maying attention to what I type I guess.
Anyways, thanks for the info...
Can I get some more opinions on cam size? I am thinking I dont want to spin the motor over about 6500rpm's, I am not looking to make insane peak hp #'s, I would actually like to build a nice torqe curve instead, afterall this is a street car and not a race car
TireFryer
a good middle cam would be like 220/224-115
