Jake brake sound
No, its not coming from the wastegate. Its coming from the inlet of the turbo. You close the throttle, the turbo doesn't just stop spinning at high rpms. But the air has nowhere to go so it comes back through the compressor, making the noise.
when you put it that way it makes much more sense, i better get a BOV that cant be good on the ole compressor.
i dont have a BOV installed on the STS system, i assumed the noise was from the wastegate , i know i need to install a BOV so that will be my winter project. what size BOV would you recommend im currently running 9psi with the plans to go up to 12-15 psi.
