Pinning balancer
Old Nov 15, 2007 | 11:30 AM
mmorellicamaross's Avatar
Default Pinning balancer
I have a camaro ss with vortech supercharger on and I want to pin the balancer because it continues to come loose. I just purchased a pin kit from vortech does anyone have any insight on how to pin the balancer?
Old Nov 15, 2007 | 12:42 PM
Inspector12's Avatar
TT-TECH Veteran
Well if I am not mistaken they install the balancer and then install the drill fixture with the bolt and then drill it and then install the pin with a new GM bolt. I personally used the ATI pin kit which has a drill fixture that goes on the end of the crank where the balancer would with a bolt and then drill through the crank and the 3/16's pin acctually sticks up @ 3/16's of an inch in the balancer's keyway. Either one works. I bet if you looked on there web you could download the installation instructions etc... Good luck!
Jeff
Old Nov 15, 2007 | 09:25 PM
Moz's Avatar
Moz
I double keyed (Milled) my crank!
Old Nov 16, 2007 | 05:09 AM
TT-TECH Veteran
Well that is best if the car already has the motor in it then you have to do one of the above mentioned things.
