Car is running.....
Old Jun 19, 2003 | 03:58 PM
BIGBOS's Avatar
Default Car is running.....
Tom over at Speed called me up earlier today...
I talked to Larry & Tom when I called back and they said that the rings have been seated, and the motor runs really smooth, they had to make a few adjustments with the HAL's because of the weight of the iron block, but it sounds like its ok....I was told that the car sounds like a Jet going down the street with the ATI race ready BOV...
Tuning should take place either today or tomorrow, possibly have the car back friday, if not, then monday..
I can't wait....
Old Jun 19, 2003 | 04:08 PM
Malicious's Avatar
Default Re: Car is running.....
Can't wait to see what #'s it puts up
Old Jun 19, 2003 | 04:38 PM
Phate's Avatar
Awesome, keep us posted!
Old Jun 19, 2003 | 05:29 PM
dug's Avatar
dug
Hey Bos
What kind of hp are you expecting? Im predicting 590rwhp if the engine sees 12lbs of boost. Heres my calculations...
375rwhp n/a * [12lbs/14.7lbs * 70% supercharger efficiency + 1] = 590rwhp
I use a conservative n/a power since your runnin through a unlocked converter and the engine is designed for boost. Does this sounds about right? What exhaust are you running?
I cant wait to see the results because I was thinking of building similar setup but am unemployed and broke as a joke. Good luck with your car. Hopefully you will get it back by Friday.
Old Jun 19, 2003 | 09:49 PM
VINCE's Avatar
Shorty Director
Pls keep us posted..
Old Jun 19, 2003 | 10:50 PM
BIGBOS's Avatar
I hope to see as close to 600rwhp as possible...
Thats if I hit 12psi...I'm sure the motor will also get stronger with miles, so the inital break in # might not be as high...
Its also going to be through the TH400 w/ a 3500 unlocked converter, 12-bolt, and on 27x11.5x15 Hoosiers...
I have FLP longtubes with, ORP's, through either the cutout or SLP dual-dual...probably going to be dynoed with the cutout open...
Old Jun 24, 2003 | 10:50 AM
dug's Avatar
dug
Hey Bos
Did you get your car tuned yet? I forgot to take into account the intercooler when calculating hp. How much do you think its worth? 50-75hp? It should get you over 600hp.
Old Jun 24, 2003 | 12:10 PM
BIGBOS's Avatar
Nope, there was an issue with the blower pulley lining up with the crank pulley, so I had to order some shims, but if all goes well, it should be tuned at the end of the week....
 Michael S. Palmer
