Nitrous intercooler spray
Old Nov 18, 2007 | 10:17 PM
detroit_903's Avatar
Default Nitrous intercooler spray
I have a 94 z28 with a STS kit. I'm currently running meth injection. Next summer I plan to run a fmic. I wanted to run both intercooler and meth. Also I was thinking about the nitrous intercooler spray. For a triple cooling effect. Would that be overkill or could I use all 3 sources??.
Old Nov 18, 2007 | 10:23 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
The only reason to ever run nitrous to cool the intercooler is if you aren't allowed to spray it into the TB. It WILL cool the intercooler, but the effect is much LESS than just using it as the usual power adder. If you are going to the trouble of plumbing a nitrous kit, you may as well get the real benefit from it. BTW, it would definitely help with the STS lag.
Old Nov 18, 2007 | 10:29 PM
They claim to get an extra 50rwhp using the nitrous as a intercooler spray. That's basically all I want - Plus It's not a direct spray in the intake which means my stock engine should last a little longer. I really dont want to run nitrous I just want to run it as a intercooler spray
Old Nov 18, 2007 | 10:31 PM
gametech's Avatar
Just using nitrous as an intercooler spray would be like just getting a ******* from a $1000 a night hooker. BTW, anything that makes more power is harder on the engine. How many motors have you heard of that blew up from a 50 shot of spray?
Old Nov 18, 2007 | 10:39 PM
code4's Avatar
IF you must, use Co2, it is cheap.
Reject's Avatar
a lawnmower engine
Old Nov 18, 2007 | 10:48 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Some info in here: https://ls1tech.com/forums/showthrea...us#post5687435
Old Nov 19, 2007 | 07:44 AM
red beast's Avatar
I just read an article in one of the ford mags, either muscle mustangs or 5.0. they had an procharger 347 on a dyno and sprayed the intercooler with nitrous...they saw iat temp drop 4 degrees with NO gain in power...the shop said it's a waste of cash to buy a kit, refill bottles and have the extra 25 pounds in the trunk for NOTHING....just thought I would share....
 Michael S. Palmer
