best head for FI
Old Nov 29, 2007 | 04:22 AM
Inspector12's Avatar
TT-TECH Veteran
I vote AFR's simply because I have not seen another car make as much power as mine on 9.4psi with 11.4 afr & 14* at 6k. They must flow pretty well. Numbers in sig
BY NemisisC5
That is because you haven't seen my dyno sheets LOL! Whats' up Scotty? I have both AFR's and TFS's heads the TFS"s have a slight advantage although it isn't worth mentioning on a FI car probably. Take your pick you will be fine try not to look stress over it they are all good FI heads and the deck thickness is the main thing. Good luck.
Jeff
Old Nov 29, 2007 | 06:21 AM
lmt0705's Avatar
what head do you think would make more power then is the only other question I would have? AFR,ET,or ALLPRO
Old Nov 30, 2007 | 03:22 PM
Rubberduck's Avatar
How about the heads patriot peformance is starting to produce now, the "predator" should be a killer head with thicker deck and extreme good flow numbers.
Old Nov 30, 2007 | 04:00 PM
SuperZ's Avatar
Originally Posted by Inspector12
BY NemisisC5
Jeff
What boost levels are you at while achieving your 840-880rwhp numbers?Im looking in to the TFS 235s.They look nice
Old Nov 30, 2007 | 04:41 PM
Mike 01WS6's Avatar
Originally Posted by MIEric
Could you have a stock block drilled for the extra two holes?
Kurt at W2W did it with one of his motors. I think he may have used a stock casting head though as well and just machined the holes in the head. The block has an extra stud boss welded on the block and I think the other side is drilled and tapped....
PM Kurt and he'll be able to answer more thoroughly. However, at those powerlevels the stock LS1 block is a liability anyways.
Old Dec 1, 2007 | 12:27 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I remember someone doing the opposite too and modifying some AFR heads to use with a 6 bolt block.
Old Dec 1, 2007 | 11:29 PM
NemesisC5's Avatar
BY NemisisC5
Jeff
S'up Jeff??...Hope things are going well Bro....Post Your Charts
Old Dec 2, 2007 | 12:27 AM
DanZ28's Avatar
I like the AllPro's, kick *** head on there 6 bolt version. Would take it over any of the other heads.
Dan
Old Dec 3, 2007 | 01:10 PM
john_sblendorio's Avatar
I would think the exhaust flow would be of higher importance than intake since the intake is pressurized?
Old Dec 3, 2007 | 01:29 PM
red beast's Avatar
I'm running the l92 heads from texas-speed with no problems, the max boost I have run so far is 16 psi....I think any head mentioned above will make the power level you are looking for...good luck....
