how much boost
Old Nov 30, 2007 | 10:25 PM
HeavyWeight's Avatar
Default how much boost
My current motor is a stock crank with forged rods and 4cc mahle pistions. how much boost can i use with a set of 72 cc heads. It would be from a supercharger with a FMIC
Old Nov 30, 2007 | 10:39 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I've got that same setup and was at 15psi with the stock 6.0L heads. I just put a set of AFR's on, so boost will probably drop a bit, but HP should go up hopefully...
Old Nov 30, 2007 | 10:47 PM
so you think i can push 16 - 18 psi with so patriot heads
Old Dec 1, 2007 | 01:50 AM
ChrisUlrich's Avatar
Get it on a datalog and keep turning it up until you see stuff you don't want too.
But that's a fairly high CR you got there, no?
Old Dec 1, 2007 | 09:39 AM
ChevyChad's Avatar
My SCR was 9.45 with stock crank, compstar 6.125 rods, -4cc Mahle pistons, and GM 6.0L heads (these are advertised as 72cc, but they are really like 71.09 from what I have read here). Also using the GM 3-layer 6.0L gaskets.
