Blow through MAF
Old Jun 25, 2003 | 05:53 AM
GoldenVelvet's Avatar
Default Blow through MAF
So what happens if you put the MAF on the pressure of the plumbing?
Old Jun 25, 2003 | 07:10 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Default Re: Blow through MAF
Most of the same things as if it were on the other side. Blow through allows bov/bypasses to be vented to atmosphere. It also is somewhat more instant at reading flow changes. Not stock setup pcv-friendly, where as the pull through can be. If the iat is built into the maf, then it will read pressurized-iat temp. Maybe a few other things I haven't thought of. All ATI kits are blow through.
