aluminum downpipe?
You also have to be careful of how you position the radius, especially when you discharge almost 90 degrees immediately post turbo. All the exhaust gas is going to slam into that like a wall and force a lot of heat into a very concentrated area. If you look at a lot of the drag cars that run straight aluminum there generally are no 90 degree bends anywhere. And if there are the wall thickness on the tubing is going to be a lot thicker. Same goes for your waste gates and where / how you direct those back into your downpipe. The turbo will take some heat out of the exhaust but when your waste gate opens there will be very little temperature drop in comparison and that can really cause the fun stuff. You're not going to want to have your waste gate pipe into the downpipe pointing into any bends or 90 degrees to the pipe. The longer an approach you can give it, the better off.
The first aluminum downpipe we had for the Red Rocket ended in a mild disaster as we blew out a sizable hole the first pass out. A combination of both factors mentioned above. The new setup takes away some of the heat first by using steel off the turbo and then aluminum the rest of the way after the second bend then it's completely fine from there. You can get aluminum to steel v-band assemblies from several places.
