Max boost with Stock compr w/ built motor
Old Dec 30, 2007 | 01:44 AM
tilly's Avatar
Default Max boost with Stock compr w/ built motor
Hey
I have an opportunity to purchase a 347 cu in forged short block with mahle pistons and scat rods. It has a flat top piston with 4cc valve reliefs.
Now I am trying to drop the compression with different head with bigger combustion chambers. Now the lowest I think I can get the compression is 9.8:1 with a .051in gasket thickness with a 66cc combustion chamber.
Now I figured it would not be safe to run a gasket that thick in boost applications. Now what would be the maximum amount of boost could i run before I have to seriously worry about detonation on stock compression with 91 octane with a decent tune with a decent blower or turbo (high CFM)?
Old Dec 30, 2007 | 05:57 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Why not run 72cc 317, aka 6.0L, heads? That would drop the compression level lower to about 9.2? They are cheap and a great way to lower compression effectively.
Keith
Old Dec 30, 2007 | 07:14 AM
Websy21's Avatar
Keith
Beat me to it
Old Dec 30, 2007 | 11:10 AM
tilly's Avatar
SO lets say I do not use that head. How much boost could I put into my motor on 91 octane with meth injection before I seriously have to worry about detonation with a decent tune running 10:1 compression.
Old Dec 30, 2007 | 01:11 PM
NemesisC5's Avatar
Been running that for 2 years on my Corvette (Shell 93 with Torco OB & Meth)...9psi revving to 6900 having a blast pounding the street
Old Dec 30, 2007 | 03:08 PM
Websy21's Avatar
Thats nice its holding together for you at those power levels, must be fun!
