OIling on rear mount
Old Jan 8, 2008 | 12:14 AM
93blacktransam's Avatar
Default OIling on rear mount
ok i have a theory it might be dumb im not sure......on a rear mount if you ran the oil inlet line to the turbo and put a 3 way splice in it bofore the turbo and ran your oil outlet line to the last port on the threeway would you need a scavenger pump since its right thure inches to the inlet line because it just goes to the engine anyways as long as you have a check valve before the turbo inlet?
Old Jan 8, 2008 | 12:39 AM
striker754's Avatar
You will have no flow once the line fills up for the first time.
Old Jan 8, 2008 | 12:45 AM
what will it do just not oil lol, because those pumps are expensive and im doing a budget turbo
Old Jan 8, 2008 | 01:11 AM
striker754's Avatar
the oil will just sit there and get hot. it has no place to flow.
Old Jan 8, 2008 | 07:08 AM
70Stang's Avatar
If your budget doesn't allow for an oil pump, I would not turbo it right now.
Old Jan 8, 2008 | 07:30 AM
jeffyvette's Avatar
Default There is no such thing as a CHEAP turbo set up
Well... I will concede that there are cheap ones. But there are reasons for this:
1. They are junk
2. You are going to do ALOT work yourself and use OK parts.
3. You are getting a really HOT deal on a set-up and do ALOT of the work.
I believe the general thought on the matter is if you are not planning to spend at least $10k don't start.
Jeffy'
Old Jan 8, 2008 | 07:49 AM
my buget can get it but i was looking for one for like under 200 all i can find is moreand its just temerary till i get my jop in june and everything is replaced anyways.....
Old Jan 8, 2008 | 09:02 AM
70Stang's Avatar
WHY do you want to spend the money twice?
Old Jan 8, 2008 | 12:45 PM
venom346's Avatar
hey 93, If you want a new scavenge pump for undeer $200 pm me
