Another New Turbo Build
Old Jan 23, 2008 | 01:41 PM
Websy21's Avatar
Originally Posted by Frost
Yeah that's what I was gonna post; that's the one I have as well.
Same here too!
Old Jan 29, 2008 | 04:47 PM
GrandmasterCow's Avatar
Build is finished a few days ago, i forgot to update. hah. i'll have to get more pics. For my intercooler piping, i used PVC, 2.5" from turbo to intercooler, then 3" from intercooler to TB. it's a mockup, then i went and got the custom piping made and its all together. I'm working on the tune, which ill prob need some help with. I'm writing a small tune to drive it so i can get it to a dynotune w/WB.
car does idle, drives, builds boost, i have it running rich for now, better safe than sorry.
Old Jan 29, 2008 | 08:56 PM
presto_z's Avatar
congrats man.. cant wait to hear some numbers or see a dyno sheet..
what are you expecting to put down??
Old Jan 29, 2008 | 09:36 PM
no idea man, i mean i got a built motor, wish i went with lower CR pistons but oh well, i also have meth & a homemade intercooler n2o spray, so we'll see. i had some problems with the car tonight, kept hitting 8psi and the boost tube comin off but i'm going to work on a way to hold'em on tomorrow.
Old Jan 30, 2008 | 09:38 PM
presto_z's Avatar
Question: what problems were u having with the alt relocation bracket?? since i have the same kit and the same relocation bracket, im just wondering what problems i might run in to...
thanks
-steve
Old Jan 30, 2008 | 11:50 PM
I had to custom design and make one myself, the one i got from somone on here didin't work with this setup, i'll show pics/info on the setup i went with, but it didint even cost me 10$ at home depot to make, i used the angle steel, a small strip of aluminum, sawzall, drill, and some bolts lol
Old Feb 6, 2008 | 03:10 PM
presto_z's Avatar
anything new??
Old Feb 6, 2008 | 04:31 PM
deadmanTA's Avatar
Weld a ring on the ends of the pipe about 1/4 to 1/2 inch from the ends then when you re-install them just make sure the t-bolts are behind them. Remember to set the welder down you want to add material not burn a hole in your piping.
Old Feb 14, 2008 | 03:25 PM
98_LS1's Avatar
any updates??
Old Feb 14, 2008 | 04:23 PM
Originally Posted by 98_LS1
any updates??
Yup, my trans is acting weird suddenly. So I haven't been able to do any more testing until i fix it. I've got the trans out now going to flush it and fix a bad oil leak at my rear main seal (i was squirting oil after a few drives)
Old Mar 29, 2008 | 12:33 AM
maxgee's Avatar
update?
Old Mar 29, 2008 | 08:34 AM
  #32
Hah forgot to update: Project is finished and currently running @ 10psi. Vids / dyno results coming soon.
Old Mar 29, 2008 | 10:10 AM
  #33
CBIII's Avatar
bitchin'. subscribed.
Old Apr 14, 2008 | 06:31 PM
  #34
now i just have to make a cleaner radiator support and figure out what fan sizes i need, i read two 12" pushers (2,500cfm) but not sure. if anyone here knows what sizes, or know the sizes of the one(s) that came with the ptk kit, let me know.
Old Apr 14, 2008 | 09:15 PM
  #35
Sideways240sx's Avatar
I used 2 10 inch puser's. I also have the griffen radiator that everyone runs on here. If you need Part numbers for anything i can get them for you. Anyways, 2 10 inch fans with this radiator, even on dyno pulls, stop and go temp has not gone over 190's.
Post up your numbers when you get it dyno'd.
Ps... I tried to put 2 12's on this radiator, and no way to make them fit. The 10's i got are 1000 cfm each.
Chris
Old Apr 14, 2008 | 09:33 PM
  #36
presto_z's Avatar
i know frost uses 2 12" fans from spal.
actually these ones http://www.carolinarodshop.com/Store...s/12spalhp.htm
Old Apr 15, 2008 | 06:55 AM
  #37
Frost's Avatar
Yeah I do... look at the CFMs on those things, 1630 CFM each!
Old Apr 15, 2008 | 09:36 AM
  #38
hey do you have any pics ?
Old Nov 27, 2008 | 06:11 AM
  #39
CBIII's Avatar
how is she runnin?
Old Jan 26, 2009 | 08:42 PM
  #40
nice ' n good hah. once summer comes i'm switching to a 01 ecu and harness i picked up, then i can run 2 bar OS.
