CR for big boost...
Most blown alky motors are 11 or 12-1.
If you ran c-16 with meth injection, it would make less power than running straight alky.
Alky already gives you the increased octane over gas and has the intercooling effects, on our blown small block we didn't even run a cooling system on the car, no radiator no water pump.
A motor with 11-1 running 22 psi is going to make more power than a motor with 8-1 running 22 psi assuming you run the right fuel and detonation isn't a problem.
If you plan to run race gas and keep things simple I would think 8 / 8.5 - 1 with 22 psi should be easy.
of course the engines with the most power run really high boost levels, but you can bet your *** they didn't pick their heads/cam and say "how much boost can i run" they said "how much POWER can I make"
However, you can say "its just a number", but RWHP numbers are just that, a measurement of power at the rear wheels. No one said anything about how a good H/C/I car couldn't take out a boosted stock car with low boost. In the end, the more powerfull car will win (given same suspension, gears, what not), boosted or not, and frankly I'm not sure who or why you are debating this.
personally I don't like the way a car with less than 9:1 compression responds off boost, but I'm picky.
The poll is for "What CR for big boost on race gas", not "Whats the best CR for the most power". And the results clearly show that the vast majority of us disagree with you that its a good idea to run high CR with boost even on race gas.
There's no doubt you'd make more power, but you also might grenade you're motor, which to most of us isn't worth the extra few unlreliable ponies, and thats why we disagree with your opinion on this.
I would rather have a high boosted beast that I know is reliable than drive something that I don't know if it will make it home without blowing the motor. And this is just where you and I (and the rest of the majority who voted for the lower CR) differ in opinion.
Hey bro-STFU!!!!!
Let everyone build there stuff according to the pole-if not there will more an more faster cars out here!
I know what you mean bro-for example a friend of mine got talked out building his forged 347 at 10.1(they built to be 8.8.1)-then he wondered why he couldn't make the same power as I did cause he couldn't push the blower any further. So he got fed up and swaped over to smaller CC heads and picked up over 50 rwhp with ALOT less timing and fat tune. He's happy now and says the throttle response is sick!
