Turbo Question?
Old Jan 26, 2008 | 12:48 PM
Streetracer361's Avatar
Default Turbo Question?
Does anyone know if you can use the turbo off a dodge desial or ford on a 99 T/A. If so how would you make it work.
Old Jan 26, 2008 | 06:37 PM
someone has to know. Help me out.
Old Jan 26, 2008 | 10:51 PM
DrTurbo's Avatar
LS1TECH Sponsor
Way to small. Most of the dodge and Ford are only 55mm-60mm max. Plus they don't hold up to well in a has application.
Old Jan 26, 2008 | 10:55 PM
Phoenix 5.7's Avatar
people are using holsets with pretty good success on small cheap applications, mainly 4 and 6 cylinders. some of them are makin good power. but these are small cheap cars. at minimum it would take a twin turbo setup to support a LS1
Old Jan 26, 2008 | 11:00 PM
I would like to go turbo but just dont have the money. I'am trying to put one together with the least amount posible, any thought's. Where can I get just the head unit for real cheap?
Old Jan 27, 2008 | 12:19 AM
Mike2kZ's Avatar
I don't want to **** in your cheerios man, but FI and cheap don't go together. Stock parts are designed to handle stock levels of power/stress. Can your transmission handle the added power? Oh about your rear end? Can your fuel pump/injectors keep up? Oil pump? And that's ignoring the short block internals. There's alot of supporting mods to consider when going FI.
Head unit? I thought you said turbo. If there's a head unit in a turbo setup, someone please show it to me.
Cheapest route to a fairly simple turbo car: STS rear mount. Tune it yourself (Assuming you know what you're doing)
