Would a D1 be to small for a 382 Ab
Old Jul 10, 2003 | 04:08 AM
G5TA's Avatar
Default Would a D1 be to small for a 382 Ab
I was going to build a stock CI motor but i decided to build a 382 AB.I was wondering if the D1 would be to small im wanting to run about 12-15 lbs of boost.Im also thinking about running a shot of N2O to I wanting about 700 to the wheels and i waondering if the 382 with about 12 lbs will get me close to my goal? If not i will add some N2O on top of it. Also i know a guy from Dallas had a 382 with an incon kit that made some great power so im still undecited if i want to go SC or turbo. I was also thinking about a 382 with the new CAS turbo kit.Im still in the planing mode right now.Just tring to get some info.
Old Jul 10, 2003 | 07:05 PM
G5TA's Avatar
Default Re: Would a D1 be to small for a 382 Ab
ttt
Old Jul 10, 2003 | 10:23 PM
scottywheels's Avatar
no it wot be to small. I buddy is running a D1 on his 383. but yoiu are going to have to change the crank pulley and get a reichard racing blower pulley to get you the boost you want.
Old Jul 10, 2003 | 10:25 PM
also what tranny are you running. Im making 600 rwhp and im at 15 psi. You will prolly be clower to 600 unles you are a t56 then you might have a shot.
Old Jul 11, 2003 | 01:40 AM
G5TA's Avatar
Yea im running a t56 havent changed my sig. I did a a4 to m6 swap.What do you think about adding N2o to your set woulld the bottom end hold it?
Old Jul 11, 2003 | 10:16 AM
I can go up to 22 psi, Il do that before adding nitrous
Old Jul 12, 2003 | 12:23 AM
InvisibleSun's Avatar
Hey Scott- Are using alcohol injection to boost your octane or just using straight 110? If you're using the injection: how is it working out, where do you get it refilled and for how much, and how long does a tank usually last? I'm thinking about going that way on my setup but MMS doesn't seem to keen on the idea. My WS6 is a sem-daily driver... Thanks for the info!
