procharged bird
Old Jul 12, 2003 | 12:52 AM
droptop92's Avatar
Default procharged bird
what kind of times would you expect out of this combination with a good driver.
Mods are:
2002 Firehawk Blk 6spd, Chrome Wheels, Bilstein susp, Auburn Diff, Hurst Shifter, 7lbs ATI kit, 38# injectors, SLP Longtube Headers, 214/224 525/532 114 cam, ported T/b, LS! EDIT, Jwiss timing chain, Titanium Retainers and upgraded springs, Walbro 340 fuel pump,160 thermostat, boost guage. Stereo....Alpine 7398, 2 sets Focal 165ws, Macintosh MC431, Arc Audio 2500cl, 2 IDMAX 12s and FireHawk logo box from subthump.
Are we looking at low 11's on slicks
Old Jul 12, 2003 | 01:22 AM
BIGBOS's Avatar
Default Re: procharged bird
Its probably going to be a heavy car, 6-speed isn't good for drag racing, you will either break the rear, or break the driveshaft...both will eventually break, with a hard launch, especially with a procharger....car will probably weigh close to 3900 with you in it, or heavier all depending on what you weigh....
I would say higher up in the 11's with descent driving...
Old Jul 12, 2003 | 09:22 AM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
I say hi 11s.If you drive the car hard,meaning 6000rpm clutch dump powershifting you will smoke your clutch,break you 10-bolt maybe both at the same time.You would need a bunch more stuff realize your full potential.
Old Jul 12, 2003 | 10:44 AM
Crunch's Avatar
With 4.11's, slicks, skinnies, 12-bolt, aftermarket clutch, suspension, and a little weight reduction, I'd say low to mid 11's. With only a 10-bolt, and stock clutch, stock suspension, high 11s.
A 12-bolt and some good gears makes a TON of difference in a 6-speed car.
Old Jul 17, 2003 | 08:31 AM
Packy's Avatar
Yeah what he said! You will also need slicks and good clutch if you plan on dumping it at 6000rpms!!!
