Pulley help on a P1
Old Feb 15, 2008 | 02:08 PM
youngrigo's Avatar
Default Pulley help on a P1
Does any one here know what size pulley on a stock car will get me 5.5#'s - Or better yet does any one know waht size pulley to try to get 7-8#'s?
My car is completly stock w/ the procharger - I made 418rwhp on 5.5#
I dont know what size pulley i have in there now and i want to run 7-8#.
Old Feb 15, 2008 | 02:47 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I made about 6~7psi with the 7.65/4.25 8 rib pulley combo on my old P1 setup on my stock engine. It made 489rwhp in that form...
Old Feb 15, 2008 | 04:37 PM
youngrigo's Avatar
Im running the 6 rib set up right now.
Old Feb 15, 2008 | 04:48 PM
ChevyChad's Avatar
just calculate the ratio... and hope you dont get belt slip. a bigger filter will help with boost and belt slip a little.
Old Feb 15, 2008 | 05:56 PM
youngrigo's Avatar
What do you mean by calculate the ratio? I dont know the formula to do that.
i do have the bigger filter already.
Old Feb 16, 2008 | 07:09 AM
ChevyChad's Avatar
The ratio of the pulleys... If you don't know what a ratio is, look here. If that doesn't help, go back to 5th grade
Old Feb 17, 2008 | 07:48 AM
EPP's Avatar
EPP
Smile
Originally Posted by youngrigo
Does any one here know what size pulley on a stock car will get me 5.5#'s - Or better yet does any one know what size pulley to try to get 7-8#'s?
I'm going to say you're going to need a 3.75 pulley to make 7 to 8 psi and you probably have around a 4.00 pulley on there now. Bob
