turbo lt1 headers?
Old Feb 26, 2008 | 05:59 PM
Taubr Unit's Avatar
Did u try that header on the drivers side??? Any other pics of diff. styles to use?
Old Feb 26, 2008 | 08:39 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Yeah, I tried it. It hit the steering shaft and is too wide to fit between the engine and body. Here's the new one I found at the shop:
I still have to move the back primary, like was done on Dragframe's car as it's hitting the steering shaft.
RealQuick, I'm looking for something that will clear my passenger side with the ac and ps in there. I'd like to run the cross over in front of the sump of the oil pan. Then run the passenger cross over under the driver's side motor mount like you have in this picture:
Then Y the two together and put the turbo up top by where the stock intake goes.
Any thoughts or ideas? I'd hate to buy something and then have it not work. Do you think these would fit properly on the passenger side? I think they might hit the motor mount...
Camaro/Firebird 93-95 Hooker Super Comp Shorty Headers
I need to jack the car up and slide in the hooker shorty I have in for that side and see ultimately where the flange ends up.
Old Feb 26, 2008 | 09:15 PM
RealQuick's Avatar
Originally Posted by Beaflag VonRathburg
RealQuick, I'm looking for something that will clear my passenger side with the ac and ps in there. I'd like to run the cross over in front of the sump of the oil pan. Any thoughts or ideas? I'd hate to buy something and then have it not work. Do you think these would fit properly? I think they would hit the motor mount...
I need to jack the car up and slide in the hooker shorty I have for that side and see ultimately where the flange ends up.
The pic isnt the hooker 93-95 headers as you have listed. The ones in the pic wont work... they will hit the motor mount as mentioned and arent worth modifying.
Look for the dual cat version of the 3 headers I mentioned in an earlier post.
Old Feb 26, 2008 | 10:17 PM
OWN3D BY MY PROF!
I guess I should have realized that seeing as how those are the ones I currently own. Is the dual cat version of the passenger's side manifold shorter or angled different than the single cat? I really need to get it in the car and see where the flange ends up.
Old Feb 27, 2008 | 01:08 PM
RealQuick's Avatar
EDIT!!!!!!!!!
My experience... if you want the DP on the pass. side, use edelbrock single cat shorties (hookers are probably the same) or SLP dual cat headers. If you want to run the DP on the driver's. side, dual cat headers like the BBK's and the SLP dual cats could be used as well.
Old Feb 28, 2008 | 07:14 PM
Taubr Unit's Avatar
So i was looking through a stock manifold guide from google and seen these. There from a Tahoe or and mid 90's SUV. They seem they would clear the steering shaft and still the collector still high enough for room. Anyone try these??
Old Feb 28, 2008 | 07:42 PM
OWN3D BY MY PROF!
My experience... if you want the DP on the pass. side, use edelbrock single cat shorties (hookers are probably the same) or SLP dual cat headers. If you want to run the DP on the pass. side, dual cat headers like the BBK's and the SLP dual cats could be used as well.
I think I might start hacking on my single cat hooker shorty. I noticed by the pictures it's a lot shorter than the dual cat versions. I'm wondering if I can fit a 4 inch dp down the passenger side with the header in the way? I might end up trying to notch the K member by cutting a section out, hammering it, flipping it, and welding it back in. I just got my turbo in the mail today. I'm going to go mess with it tomorrow.
Old Feb 29, 2008 | 07:28 AM
RealQuick's Avatar
It will be tough... I just barely squeezed a 3.5" in there. Also, I edited my post... read it again for the hell of it.
Old Feb 29, 2008 | 12:05 PM
1bdbrd's Avatar
Just run stock fbody manifolds if thats the way you want to go. They are proven to work and are able to make a lot of power.
Old Feb 29, 2008 | 12:08 PM
Taubr Unit's Avatar
Thats what i think im going to do. Im in the process of getting some now.
Old Feb 29, 2008 | 01:06 PM
Taubr Unit's Avatar
So since my life has turned into lt1 turbo searching i came across this. Aparently these fit right in with no modding. Just a bolt up and go, there identical to the ones i posted up from ebay and the ones from ebay actually look better with how the egr air stuff is built into it. But the Hedman ones look shorter if you needed more room for the steering knuckle....
http://store.summitracing.com/partde...0&autoview=sku
Old Mar 1, 2008 | 12:21 AM
  #32
OWN3D BY MY PROF!
http://i45.photobucket.com/albums/f6...ba9efea46f.jpg
http://i45.photobucket.com/albums/f6...8814f359d6.jpg
I have, they don't fit. They hit the steering shaft big time. There's a set at the shop now and I thought they looked good, but were the worst fitting out of the bunch.
Those do look like they'd fit very nicely. They would work really well for how you plan on doing yours.
