Cam and Gear Questions...
Would I need a new cam?
Also- How would my steep gears (4.30) work with a D1SC?
As far as the gears, since you have a centrifugal blower like me, low rear-end gears (numerically higher) will help spin the engine (and hence the impeller) up to the high RPMs quicker. But if you spin up too fast you'll spend such a short time in the high RPM range that you'll spend more time shifting than enjoying acceleration. Unless you have an automatic, I think 4.30s might be a bit too much. Go with 3.73's or 4.10's.
Hope that helps.
Those are big gears but a 28" tire cures some of that.
