Those with OFI kits, a little help?
Old Feb 22, 2008 | 09:52 AM
Funkybird's Avatar
Default Those with OFI kits, a little help?
Anybody got some pics of where you mount the expansion tank? I bought the radiator setup and don't know where to mount it
Old Feb 22, 2008 | 11:23 AM
ozws6's Avatar
It mounts behind the fuse block assemblies on the drivers side.
Old Feb 22, 2008 | 01:10 PM
Funkybird's Avatar
Thanks alot!
Old Feb 26, 2008 | 05:02 PM
Funkybird's Avatar
What about the spal fans that come with the kit? How did you wire those? Mine arent turning on?
Old Feb 26, 2008 | 05:05 PM
tt427ls1's Avatar
LS1TECH Sponsor
Depending on what year car you have the Lt1 will just plug right in. Take the plastic end piece that is on the fan connector off. Then you take those wires and they connect to the factory harness. You dont have to cut anything on your factory wires. Leave the ends on and use electrical tape on the wires. You can cut them if you would like and soder them. They will work just like your factory fans.
Old Feb 26, 2008 | 06:11 PM
Funkybird's Avatar
I cut the connectors off and just crimped them together. I let the car run and get a little over opperating temp and they didn't turn on. Guess ill have to check the connections and soder them.
Old Feb 26, 2008 | 09:17 PM
RealQuick's Avatar
Joel, I have been pm'ing and emailing... please reply back with the status of my purchase. Thanks.
{EDIT} Joel emailed me.{EDIT}
Jon
