wastegate for S80/T6
Old Mar 1, 2008 | 04:31 PM
B18CYA's Avatar
Default wastegate for S80/T6
Just wondering what wastegate you guys with bigger t6/s series turbos are using? This is a 408 S80 truck manifold kit.
I need something that will hold lower boost nicely 8lbs or so and the smaller physically the better.
considering turbosmart 48mm and tial 44mm
Old Mar 1, 2008 | 06:06 PM
SuperZ's Avatar
I only run turbosmart 38 but if I could do it all over again i would do the 48mm.Ive seen good stuff from it
Old Mar 1, 2008 | 06:08 PM
Mr.MartyStone's Avatar
I would go with a 50mm JGS. The 80mm B/W unit flows a lot of air so you have to have a capable gate to hold it to 8 lbs.
Old Mar 2, 2008 | 06:46 AM
deadmanTA's Avatar
Get more than what you need. I have a T61 and using a tail 44mm, but now I can upgrade to a bigger turbo later and not worry about it.
Old Mar 2, 2008 | 03:01 PM
6techniques's Avatar
TiAL 44mm here also w/ a similar sized turbo.
Old Mar 2, 2008 | 04:05 PM
kbracing96's Avatar
Your not gona need a really large WG with a turbo with that size exhaust housing on it, cuz it will flow a lot of air and you won't need to bypass near as much though the WG to maintain a low boost number.
