Building a 408 for boost what pistons?
Old Mar 4, 2008 | 09:29 PM
skyhighsami's Avatar
no title here
Default Building a 408 for boost what pistons?
I have looked and I can get the JE pistons that with my heads would yield a 9.1 CR. With the Mahle pistons here http://cgi.ebay.com/ebaymotors/MAHLE...spagenameZWD1V it would yield a 8.6.1. I would like to make a solid 800whp at around 15-18 psi with a 88. Those are the goals that I have in mind. The Mahle pistons are a little cheaper a couple hundred or so but do I really want to save a couple hundred on something this important? The rods are 4 inch stroke Compustar and the crank is a Eagle crank all forged. Thanks
Old Mar 4, 2008 | 09:36 PM
Shawn @ VA Speed's Avatar
the mahle pistons will do fine at that power level,built several engines in that power range with mahle's,i can give you alot better deal than that on them,i can also hook you up on the je's
Old Mar 4, 2008 | 09:46 PM
no title here
Let me know and PM me. I would like to order something soon. I am not sure what the motor will make turned up but I would imagine that it would be in the 1k range.
Old Mar 5, 2008 | 06:08 AM
cablebandit's Avatar
wiseco pistons...for 1k rwhp i would go with tool steel wrist pins
Old Mar 5, 2008 | 06:58 AM
no title here
Scoggin Dickie said that with the parts that I have and was looking at 800-1000 wouldn't be a problem.
Old Mar 5, 2008 | 07:03 AM
1INSANEGTO's Avatar
Wesico turbo duty piston's and call it a day. Comperssion should be down to 8.5:1 Mine are 25CC dish
Old Mar 5, 2008 | 07:07 AM
bluecamaroz28's Avatar
What heads and pistons cc are you using?
Old Mar 5, 2008 | 07:12 AM
no title here
The heads are Dart 225 Pro 1 with a 62CC combustion chamber. With a -29cc dish it would be 9.1 with the -32 dish it would be 8.6.
Old Mar 5, 2008 | 03:19 PM
red beast's Avatar
I'm running diamond but all of the ones you are looking at will be fine....
Old Mar 5, 2008 | 03:44 PM
lmt0705's Avatar
what ever you go with make sure there 2618 and not 4032 alloy for that boost level, something with a nice thick top ring land would be nice, I went with weisco this time around but my last set were diamonds, I had no trouble with them at 16 psi
Old Mar 5, 2008 | 04:09 PM
B18CYA's Avatar
Where did you go for your weisco's? Are customs hard to get?
Old Mar 5, 2008 | 06:36 PM
call wiseco...one of the engineers brian nutter is actually a member here. Joker called me back on a saturday before for tech support
Old Mar 5, 2008 | 07:53 PM
dkrowner's Avatar
wiseco,diamond,or CP are all good for turbo motors.in yes i've used all three
Old Mar 7, 2008 | 12:08 PM
Just a thought on heads cc, bigger head cc would give thicker head thickness for boost and you can reduce piston cc and your pistons will be thicker, too, for boost.
Head cc of 72 and piston cc of 10-15, for around 9:1 SCR.
Old Mar 7, 2008 | 12:14 PM
pozesd99''s Avatar
go with the guys at va speed. they are building my buyilt 402 block with afr 225cc heads etc...
Old Mar 7, 2008 | 02:19 PM
eb02z06's Avatar
Listen to boys on this thread-Wiseco all the way!
Old May 16, 2008 | 03:21 PM
BLWNLT1_T/A's Avatar
What do wiseco go for? I am looking for a -24cc dished/coated pistons with rings for an LT1. Can anyone point me to the right vendor. I seen a picture of one but lost the post of that vendor
Old May 16, 2008 | 04:28 PM
99 black ss sj's Avatar
my motor 408 motor is being built at speedinc right now and fraser was a lot of help to which piston to go for a boost engine, the piston i am using is wiseco 2618 forging -8/-15/20cc pistons compression around 9.1
Old May 17, 2008 | 08:18 AM
Mr.MartyStone's Avatar
Another guy running wiseco's here. They get my vote.
Marty
