STS Observations and Questions Inside - Other Dyno Sheets Please
My stock manifolds are flowing 900ish HP of exhaust. Here are all the things that a friend and I have been figured out through testing.
https://ls1tech.com/forums/showpost....71&postcount=2
If you want a high horsepower package then it will require a bigger turbo which tends to make the operating range much smaller like a big HP Supra and pretty much be a roll on racer since from a dig you will most likely get spanked. If you have an auto at least you could use a trans brake to build boost I suppose.
I guess I have always been a low end torque guy and that is what a conventional turbo setup will give you no matter what the build. I will still have to do some of the basic testing for Ronnie to see if the engine is fit as far as the 5900 RPM drop is concerned.
Thanks again for all the info from everyone and time for me and Ronnie to get together and figure out his goals with all of this info.
Mike Norris
If you are over in Iraq then you have a lot more important things to think about then Ronnies car. You info on this is greatly appreciated as well as your service overseas.
I saw your post about 700 RWHP on pump gas and I could not find out much more info. Looking for a few basics.
How is the exhaust setup? (stock manifolds? piping size(s) to the turbo? wrapped or coated?)
What size turbos as well as compressor and turbine housings?
STS intercooler or custom? If custom what size?
How is the pressure side setup? (piping size(s) turbo to intercooler?, TB size, intake manifold style and size?)
Engine package? (cubic inch, compression, heads, camshaft)
Do you have a dyno graph based on RPM rather then MPH? With HP & TQ?
What RPM does boost start to build and what RPM does it peak at? How much boost?
This will help me compare to what I am up against so much. Thanks and be safe in Iraq.
Mike Norris
No worries... dont thank me. I am an over-paid contractor!! Thank all these guys in uniform over here (I will pass it on to some) that dont get paid crap and work their asses off!!! They are all my personal heros.. (Stepping off soapbox)
Ok... answers are below:
The current turbo is a PT88 with a .96 AR from Forced Inductions
Current is a custom 1400HP rated intercooler.... last setup was a cheaper basic from TRT.
Built 408 with Wiseco -32cc Dish pistons, 72cc stage one heads, custom Cam
Do you have a dyno graph based on RPM rather then MPH? With HP & TQ? Right around 8.2:1 CR.
Hope this helps... If you are looking for something less custom and more "STS" I can help with info there too... but would reccomend TRTurbo here on the board, he built me a STS Setup that pulled 607RWHP with a T-67, 6.0L Heads, GT-7 Cam, cheap intercooler, etc...
We're going to retune for 14-16psi with a couple minor changes to the basic setup like fixing the methanol and changing a couple hot/cold side items, and I think that will prove to be more than enough as long as the heads stay down.
As it sits, it is completely overwhelming the tires to 4th gear. Freeway pulls are absolutely insane. I just want it to flatten out a bit and be ready for the suspension.
Thanks again.
Mike Norris
